Category 1 or 2 hitch.
61uni
Can someone tell me which one this is?
In the picture, the caliper appears to be laid down and out of square in the bore so I was guessing based on those things the reading is smaller than the actual bore size. If that is a square, centered, true reading; I don't disagree that my guess is wrong, they don't shrink. In that case it may be a worn 7/8 ball from a Cat 1 lift arm. Or it may not have a thing to do with a 3 point hitch.
could that be part of an old trailer hitch ball? i have a few old ones that came apart like that 1 7/8 i think
(quoted from post at 19:33:41 03/25/21) Apparently I was measuring the top link pin instead of the pin that goes through the ball.
3/4" diameter top link pin is for Cat 1. Cat 2 top link is 1" diameter.
Where/what is this ball from, or is it something you found?
I didn't go out to the shop and mike the inserts for a comparison to what you are showing, but the Ford 3910 is setup with Cat II lift arms but has removable inserts like that whereby you can insert a Cat i or II socket to fit your implement.
