Harry in Ky
- Location
- Central Kentucky
This question is aimed towards those who rebuild pumps, or those who know and understand the inner workings of them. I guess I understand the basics, but certainly not everything. The DPA pumps used on many of the Ford tractors from the seventies through the early nineties had a side cover with a fitting/return(?) line leading to a port on the filter base. Also a return line on the top cover that returns fuel to the tank via the injector return line. Non of which used any sort of restrictor orifice to affect case pressure. Why was that necessarily (if indeed it WAS) better than the more common return fitting mounted on top of the main case mounting flange as used by most other engine manufacturers like Perkins, John Deere, Fiat, Kubota, ETC? Was that just another one of "Ford's better ideas"?
