cc-a cultivator
bass
hay green folks. any of yall know of a place where I might find CC-A cultivator. im in need of some parts and here in e.texas cultivator parts are un heard of...
John Deere no longer has parts for this cultivator so im left looking for salvage.
thanks for the help
bass
53superC
Try Bowie equipment in Tipton Iowa. Jim has a huge salvage yard with a good many implements. There is also a Kalsum Salvage at Waterloo Iowa but I think he is closed until sometime in March. Tom
This cultivator, that the seller calls a "chisel" has been for sale near Salina in central Kansas for probably at least a year for $50. I don't know what brand it is and the seller apparently doesn't either. If it is a JD I would be interested in it but the seller doesn't have any way to load it so...?.
(quoted from post at 11:17:29 02/06/20) This cultivator, that the seller calls a "chisel" has been for sale near Salina in central Kansas for probably at least a year for $50. I don't know what brand it is and the seller apparently doesn't either. If it is a JD I would be interested in it but the seller doesn't have any way to load it so...?.
<img src="https://www.yesterdaystractors.com/cvphotos/cvphoto4368.jpg">
You could lay a couple of planks up to the side of your trailer and winch, or pull it on with your pickup.
That is NOT any CC series cultivator. If it is a Deere it is way older than a CC cultivator. I used the CC147 and had CCa for parts. On a CC series the wheels are inside the frame.
