Swarty1973
Im restoring a CC Case and just had new bearings poured in the connecting rods and main bearings, head totally redone with all new valves, guides and springs. I have a DC rocker assembly for my CC head id like to install because the cc didn?t have oil to the rockers. The CC assembly has 4 cotter pins to keep the rocker shafts in place. The DC assembly has 2 cotter pins, one on the front and one in the back and the tee in the middle for oil from the block. I can install the DC rocker assembly and grab either rocker shaft and pull them out. What keeps the rocker shafts from sliding forward or aft on a DC head?
Also, any tips on running oil (internally) from my CC block to the DC rocker assembly with a CC head? I know the DC had a tube from the block with a 1/8? restriction hole to the rocker assembly. I was thinking maybe teeing off my center bearing oil fitting, adding the 1/8? restriction and weaseling a line up by the push rods. Let me know if anyone has a better idea. Thanks
