cca front end swap
HI: Yes the the parts from each tractor will fit the other one you will have to revirse the arms off of the sterring box.
i believe the C and CA would interchagne directly.. The smaller B would steer backward and need the steering box changed also.
These front ends are a bolt in swap. Just need to use the CA front sheet metal to accomodate the cultivator mounting boss. Or cut holes in the C sheet metal. Kip
