Southern Ray
- Location
- south Texas
years ago I used a chain fall that had no moving parts except for the chain and sprockets.
this was over forty years ago.
The upper block consisted of two sprockets, one larger than the other and fastened together.
The lower block had one sprocket.
The chain was a continuous loop through the blocks.
To raise the load you pulled the chain from one side.
To lower the load you pulled the chain from the other side.
The differential size of the sprockets in the upper block accounted for taking up the chain loop to raise the load and paying out the loop to lower the load.
The hoist worked well for my needs and I didn't experience any problems.
Over the years my career has changed and I lost association with this type of hoist.
I did use the lever hoist and the common chain hoist we now see.
I have two cable type come-a-long hoist.
I no longer see this type of hoist. Was there a problem with the hoist?
Has anyone used these hoists, or still have one?
