chain saw gas cap
Ted in NE
Have an older Poulan saw. Leaks gas out the gas cap vent hole. Can not get the cap any more. Can a person get a replacement valve for the old cap?
I had the same problem with Stihl weedeaters, fuel cap broke. I could get a new cap but it would cost over $20.. So I started buying used weedeaters at auctions that were the same model as mine for less than $10. for the whole machine. Now I have plenty of spare parts when I need them.
I have the same problem with a Stihl, last summer I bought a rubber cork and drilled it for a vent tube. In a few weeks it swelled up so much that I can't use it any more, and it was ethanol free gas. I have an old weed-eater, I will try that cap.
(quoted from post at 14:03:55 01/19/17) Model SD25 S/N 25640599. Is A 14" Has a flat threaded cap.
Thanks for the replays.
Ted
t had a duck bill vent in the center of the cap facing down into the tank. I picked up a new one 4 or 5 years ago at an old shop here for around ten dollars. I do not know how those older one are held in but the newer ones have a star spring washer that holds them. I will try and look at mine and let you know.
I looked at mine a minute ago and as I said it has the duck bill vent in the cap held in with star washer of sorts. Saw shop should have the little vents.
Here you go- brand new. http://www.ebay.com/itm/Poulan-Chainsaw-S25AV-S25-CVA-S25DA-Counter-Vibe-Fuel-Cap-10123-/322372244058?hash=item4b0ee2125a
Here's a link to the duck bills- http://www.ebay.com/itm/5-Pack-Duck-Bill-Check-Valves-Fuel-Cap-Fits-Homelite-Chainsaws-XL-XL2-Super-2-/400694794308?hash=item5d4b455844:g:pzsAAOSw-nZToTR1
jackssmallengines.com will have your gas cap.
They will require make, model, s/n when calling their 800 phone number.
HTH John,pa
