Chaining down 3pt for Ford 711???
Hello all,
OK, I bought a 711 for our 860. The budget barely stretched enough for me to get the loader, so a valve was not an option. I know several of you mention chaining down the 3pt but HOW? My copy of the installation guide shows the original Ford kit using tubular steel arms. Obviously these kits aren't going to be something I can run right out and purchase. Can someone run through exactly how to chain the 3pt down? Where do the chains run? Does the 3pt get chained all the way down or all the way up? If I'm going to use a filled barrel for a counterweight I'll need to know this last part especially so I know the proper placement of the lift pins.
Photos and talking reeeal slooow would be helpful! LOL!
Thanks all,
Mike
Mike;
Altho we didnt have loaders on the 850 or the later 2000 we had the kit(or whatever you call it)installed so all we had to do was turn a valve for remote hydraulics.
To chain the lift arms down we would lower the lift arms and wrap a chain around the axle and the lift arm. Do this on both sides. You cant use the three point lift then.
steveormary
Mike,
What Steveormary says.
Add to that, it's the Upper lift arms - the ones that rotate on the rockshaft in the top cover that you chain down.
Then I believe you can tap into the port in the blank cover under the front of your seat and use the touch control lever to operate your loader.
Your 3 point will not work so get a different plan for counter weight.
Welcome to the One Armed Bandit Club.
There's several of us here who think they're the cat's meow.
Yep mike, as the other said.. lower the lift, wrap a chain thru/around the upper 3pt lift arm knuckle and then cahin it to the axle on both sides.
If you are gonna hang a counterweight, make sure the counterweight is set so that it is off the ground and being toteted on the 3pt lift at it's lowest position.
I did that with mine.. I leave a piece of timber int he apsture if I want to drop the concrete off the 3pt. the timber is just a hair taller than the distance between the counterweight and the ground.. thus i can lift the counterweight and set it on the timber.. relaxe the lift and unpin it.
For this setup to work, you will nee dthe trip bucket style... if yours is hyd, you will still need a valve. though can get by with a cheap OC dual log splitter valve. run power from t he option port to the valve, and the return form the valve run it to a fitting that is tapped into the hyd fill port under yer seat onthe left side. when you lift the 3pt handle oil flows thru the OC valve back to the sump.. when you work one of the circuits ont he valve, you can run the lift/drop or the dump/curl on a hyd loader.
if yours is the trip dump style.. all you need is the 2 chains, and 1 piece of hyd line to run from the option port on t he top cover to t he hyd cyl.. lift 3pt to lift loader.. lower 3pt to drop loader..
Post some pics of your loader.. even during instalation.. and of your plumbing. So far I have not seen any examples of the cheap and dirty 3pt setup.. but would like to.
As UD said.. many of us here get plenty of use out of our 1-arm bandits. I just moved some round hay bales with mine earlier today.
soundguy
Thanks guys. The loader is the basic 711 with trip bucket. I bought a new line and fittings and the hydraulic cover plate had already been tapped for a loader years ago.
Again, the budget won't do a valve right now so I'll be doing the quick & dirty with the 3pt controls. Sorry if I wasn't clear earlier.
soundguy - You mention you've not seen any examples of the cheap & dirty setups. I'm confused. Why are you guys chaining down your 3pt lift if you're not using the 3pt controls for the loader????
I will try and remember to take some photos in any event.
Thanks all,
Mike
If you're going to use a barrel full of concrete for a counterweight you need to mount the pins on it so that the barrel is off the ground with the lift arms all the way down. As soundguy stated you will then need to set the barrel on blocks in order to remove it. When you get the barrel attached to the 3PH you will need to lower it all the way and the install your chains. I have a copy of the manual for the 711 loader and it shows a piece of steel tube or pipe with the ends flattened and drilled. One end is fastened to the knuckle joint and the other end is fastened to a bracket that is bolted to the fender mounts. You can do the same thing with a short piece of chain connected to the knuckle joint and then wrapped around the axle. When the lift arms are restrained in this manner the hydraulic pressure created in the lift system when the lever is raised is diverted from the lift cylinder to the port on the accessory plate under the seat.
My Grandpa used to use the same loader on his Jubilee, also w/o a valve. He used chains and brackets that he got with the loader (from our Ford dealer), but the brackets are not quite like what has been described by others. More like a 1/2" thick flat piece of steel with holes/slots in it for the chains and U-bolts. We sold the loader several years ago, and the buyer had a valve for his Jubilee, so we still have the chains w/ the bracket and U-bolts hanging in the gargage. (Interested?)
