SHLaverdiere
What does everyone here think of champion spark plugs i just want the general publics opinion is all the h10 in a ford 8n
(quoted from post at 06:56:59 06/02/15) im gonna get a new set tomorrow at my local napas and since its a ford product im gonna put a motorcraft plug in it the plugs that are in it now i cleaned them 5 times tonight they just keep fouling the tractor does run for a little bit then the plugs foul in it then i gotta take them out and clean them again so there cooked
(quoted from post at 22:11:32 06/01/15)
Why do you spec all my tractors run well no issues at all with used carbon core plug wires (all good used OEM take off's)... Am I that lucky maybe...
For all the copper core lubbers this would be the best wire fer'ya...
its a life time supply
http://www.homedepot.com/p/Cerrowir...ound-Feeder-UF-Wire-Gray-138-1602CR/202206550
(quoted from post at 08:25:14 06/02/15) sorry there dude but on a low energy ignition system like that carbon core isnt the proper thing to use because theres not enough power sent threw them to the plug those old points and condenser setups arent like todays coil packs where there is alot of power going threw them so solid core is alot more logical and you just have better fire from the distributor cap to the spark plug with no resistance in between
