changing front trans. seal on 22
Savinsam
My front transmission seal which attaches to the universal joint assembly is leaking pretty badly on my "22". What do I disassemble to get the old seal replaced? Thanks.
(quoted from post at 00:42:59 04/23/19) My front transmission seal which attaches to the universal joint assembly is leaking pretty badly on my "22". What do I disassemble to get the old seal replaced? Thanks.
IFRC, you need to take the universal joint apart, that is bend the locking tabs back and it will unbolt. Slide the drive shaft to the front and it will come off. Not a lot of room , but take your time. Then, drain your transmission case down and take the cap screws out that hold the seal.
Been a couple of years since I did mine. Take time to look the parts manual over.
