Changing oil
37chief
Location
California
I have been changing my own oil in everything with a motor, starting in 1957 with my 48 Cushman scooter. My tractors have a lot of room to move around to get the drain plug out. My cars are a different problem for me. I use ramps to drive up on, and put down a pieced of cardboard, and wiggle under on my back to perform the oil change. A little higher would a lot better. I see on the internet separate hydraulic ramp lifts for each wheel, that will pump up to 15 inches which would be a lot better for me, made in Chine of coarse. Anyone ever use something like this? I see different people selling them for $60.00 and up, for two. Seams a little cheap. A scam? Any thoughts? Stan
Without a pic I’m not exactly sure what you are looking at….
Project Farm, one of the best YouTube channels out there in my opinion, reviewed something like you are describing, and as I recall it was very poorly braced and just looked dangerous to me. It bound up for him as he used it. I’m sure one else will put up a link quicker than I can find it.
I do not know if that’s the same thing you are looking at?
Paul
I edited this, as I was recalling 2 different items. Several on line reviews are middle of the road on it, but it really looks flimsy to me with flat iron instead of angle iron holding it up. Very short welds are used to keep the jacks in place, with the vehicle extended up it has a lot of side sway on those short welds. But, some like it.
I do the same, and your right, a few more inches of height would make a big difference on these wore out shoulders. The trucks aren't a problem but the cars have front air dams that need a two inch board in front of the ramp to clear. I've had to make a board ramp to get on the steel ramp. Thought of putting a two by twelve under the ramps but that would compound the problem, and try to scoot on the board.
You could have a set of ramps custom made. Taller and a little longer ramp would make a big difference.
I have a set of the pump up ramps. Got them on Temu for a $110. They work just fine. Be aware once your on the ramp if you use the jack then you should also use a jack stand.
I've gotten soft and just take the vehicles in to be serviced. Equipment I did myself.
Vito
Last 3 new vehicles i bought i let dealer service. Actually not a lot cheaper to do it myself anymore. Dealer keeps up with factory service intervals. Also if they find something they provide me with a loaner vehicle. Once got ran off interstate on a trip. Did not feel anything or notice a problem. Had a oil change the next week. Dealer found the rack was leaking. Asked me if i hit something. Told him of being ran into median. Yep. Must have hit something. Filed an insurance report and was only out $100. Gave me a truck to drive a couple days and fixed it. Still do the tractors and my 93 pick up.
I use two good floor jacks, located at the jack/lift points located close by the rear of the front wheels on most all unit bodies, lower a-frames on some and under the axle on really old or big stuff. A couple of jack stands for safety.
Can usually get plenty of room that way. Does take of couple or trips side to side to hit on jack then the other without leaning it too much.
When I had a boat with an inboard engine I used a hand pump with a tube to go down the dipstick hole. Worked fine I don't know why it wouldn't work on a car.
I've got an old long lever floor jack that I use. Find a good center point to jack whole front end and jack wheels off the floor so I can check wheel bearings and steering . Always throw a safety block under just in case and have room to work .Some newer vehicles have so many under shields that it is difficult to find a lift point and drain plugs and filters .
I did our car myself this spring for the first time, Ford Edge. I was surprised to find a complete belly pan, had to take out a lot of screws with 7mm heads. Planning on doing our truck this fall, surprised to see it has the old-style canister oil filter, a 2024 F150 2.7 turbo.
My 2021 Tacoma has a filter housing that you remove old school and there’s a paper element. I consider it to be a pain. You have to drain the filter before you can remove it.
On the other hand our 2021 Subaru WRX has the filter in the engine compartment. Right in front. Easiest to change that I have dealt with. Just did it today. By the way I used a floor jack and jackstands.
If you look under the car near the front of the rocker panel you should see the lift points with V notch cutouts. That's where you place a jack to safely lift a car. If you use the trailing arms or other suspension parts. You run the risk of damaging them.
I change oil on the tractors but my new pickups go to the dealer. Not only do they change the oil, they also keep up with the entire maintenance schedule in the manual AND software updates. Besides it is not as much fun as it used to be crawling around under a vehicle.
I thought ramps would be a great idea.....not so. They are in the way getting to things under the vehicle and tend to slide on concrete floors.
