Ferrell Andrews
Hello Again. I am a new owner of my first 8N and after all the great advice I received here regarding my '48, I was able to get the garden in and now time for some routine service. I have looked through all the service manuals and have a good idea of the how, but have several questions and want to verify:
1. I know there are three drain holes for the tranny/hydraulics, two are 1 1/16" plugs and the other (rear) is a square plug, correct? Pic attached. I am going to use the Travelers brand mineral oil 90W as the replacement oil. How do you determine the level to fill. I think I read somewhere to take out the lower inspection plate cover bolt on the right and fill til it runs out, correct?
2. The oil bath air filter. I cleaned the bowl out and replaced with fresh motor oil. How do you remove the screen filter cartridge to wash in gas? Does it just pull out or is there a release?
3. Obviously the drain plug (also 1 1/16") for the engine is on the bottom of the oil pan and should be drained warm. Which grade oil would you recommend 10W-30?
4. Any particular grease for the grease fittings? I usually use a marine grade (blue lube)in my gun but would this be ok for this app or just normal joint lube?
Thanks again for all your help, really enjoying my tractor and this forum
F
F
