Ken Hoover
I have an Autolite GMB 4804B generator that I could not find a replacement or rebuild kit for when I discovered it was not charging the battery. I found a hit that a Prestolite GHD 6001 would fit my tractor, but did not say it would work on my 49 Massey Harris 22. My current gen is positive ground. The replacement I am not sure about, but spins counterclockwise when my original goes clockwise. I was led to believe my old gen was toast because the field and armature showed continuity when fully assembled but so does the brand new gen.
I put the old Autolite back on, and when I connect field to case ground, and armature to gen connection on my relay, I get about 7+ volts which seems right, but the generator gets hot to the touch. Is that normal? I do not recall connecting F to case before, but ammeter is showing 15 Amps at mod RPMs. Trying to preserve the generator since i cannot find a suitable replacement or alternator conversion kit. Any help or confirmation is appreciated. I have a shop book, but the electrical drawing does not clearly show where F is connected since it includes lights, which my tractor never had.
