gooseroller
Any ideas why the charge indicator light on my 981 won't shut off even when the key is removed from the tractor?
y way of the stuck contacts in the VR that you were told about. Whack it with a hammer or replace it.(quoted from post at 16:12:27 10/28/15) When I have the charger on the battery, the generator is hot to the touch, that doesn't seem right to me, the ignition switch is off but there is current reaching the generator somehow?
es, people have experience with a single thing/alternator & ever after they some how think that all others are exactly the same!! Even ALL 10SI alternators do not behave the same. GM changed the VR design along the way. Early 10SI units went to full output when they lost the sense input, but later units went to Zero. Generalizations are almost always wrong!(quoted from post at 20:02:32 10/29/15)
Reminds me that when alternators first came out... Motorola did a commercial where they pulled out the battery and drove the car cross country with out a battery, showing how reliable the alternator was. Even at idle, it supplied enough power to keep the car going. The voltage regulator kept the voltage at 14.2 volts.. with or without a battery. They even ran it up in Alaska. Of course they had to use a battery every morning to start the car, then till it parked then next time, no battery.
