Charge pump JD 9500
On my 9500 I'm having trouble with it stalling (two lights come on I think one is pressure and parking brake) when I'm in 3rd gear. It will also stall in iow gear with the grain tank full. Done some checking and have been told it's the charge pump how can I trouble shoot it to make sure that is what it is, also been told I need to change the hydrostat if I change the charge pump is that true? Can the charge be rebuilt or buy new or used? Any help would be appreciated. Thanks Roger
If you need to replace the hydro it best to do both from what I was always told try these guys they are very good.They will send you a test kit and walk you through the process
https://www.herrshydro.com/
The hydrostat has got weak. As a rule the entire unit as in hydro pump/charge pump and drive motor is replaced or rebuilt....hydro/hydraulic oil and filters changed.
