Charging lithium battery
ldj
I have 18v battery with out charger. I have battery charger for another brand battery that won't fit. Can I make up wires to between the battery charger to the battery without charger and charge it?
Are the batteries the same "technology", both nicads, li-ons, etc.?
What's the "rest of the story", is this to be a one-time thing to get some charge in a battery to verify if it and the "gadget" it's used with function, or a more permanent "solution"?
What's the gadget? Mite find the proper charger on ebay reasonably, or even at a thrift store, if it's a relatively common item.
I recommend you buy the right charger. Over charging can cause fires or shortedn the life of the battery.
Check out chargers on Amazon,. Not that expensive
Lion batteries multiple cells connected in series. They should be charged equally which is why there are more contacts between the + and - terminals. The charger monitors each cell.
