I recently got a Ford 841,when I first got the tractor it was not charging so I had the generator rebuilt and replaced the regulator to be on the safe side.The first reg. lasted about a month before it quit charging.They replaced it for me, the second one lasted about 30 min.then it stuck closed and drained the battery after shutting the tractor off. I then got one from CNH,now the problem I'm having is when first starting the tractor it doesn't want to start charging until you bring the rpm's up to approx. 2000 then the light goes out and it charges fine until the next time you start.I have considered putting a juicer button on to start it also.I would like Thank You in advance for any help with this matter.
