This is a followup to yesterday's post. This morning I tried Soundguy's suggestions,genny started and motored along fine.I hooked vreg back up no charge at all no matter the rpm's.So I hooked a jumper wire up and full-fielded genny,light went out and stabilized around 7-7.5 volts at 1500rpm's. I left tractor sit for awile then started back up,same as before 2000-2100 to start charge,then will charge fine untill next time.It did not do this when I put the vreg on untill it had been on about a month or so. That is what has me curious,if this could be another bad vreg? Maybe bad ground at vreg???
