Longmeadow farm
Re: New Holland T4.75 with 4wd and loader.....frame twisting is loosening chassis bolts...
Has anyone had experience repairing/fixing transmission/rear end case threads using a thread repair approach such as heli coil or something similar. Tractor twisted the bolts loose after 3 years of service. Changed bolts, cleaned bolt holes, etc... lasts about 9-12 months and loosens up again... leaking fluid et al...,
I believe that the tractor is too light for the loader a 655 TL which is used on NH tractors that are 2000 lbs heavier. I've concluded that,in my application, I need a heavier chassis tractor.
Please keep the commentary directed at the possibility of case/chassis thread repair. Dealer has not been that all that helpful
thanks
thanks
