check chain quality
JT90
I need check chains for my ford 3600. You can buy aftermarket kits for 30.00. I just priced NH and it was 115.00 a side.(bracket, chain, u hook with pin). There has got to be a differents in quality. Has anybody used these aftermarket kits and are they any good.
I have several after-market sets in use. I've only ever broken one, and that was my own dumb fault for not setting my two-bottom plows up correctly. Even good chains can only take so much abuse.
Good luck.
Ray
You will find that the chain itself is not the weakest link.
Buy the cheaper ones.
(quoted from post at 01:56:46 02/02/13) You will find that the chain itself is not the weakest link.
<img src="http://i61.photobucket.com/albums/h56/Ultradog/100_02171.jpg">
So are you saying use cheap chain buy higher price bracket.
What all are you missing?
I found out that the brackets are not all that strong. Though I was abusing the thing with an 800 lb Bush Hog rotary swinging back and forth and no stabilizer bars.
If you are missing the brackets too then I would look for some used ones. Am pretty sure they are all the same from the Hundred Series all the way up.
Someone here on this board would probably have a pair they would sell you reasonably.
Then buy the $30 set of chains.
Some things at the dealer are worth the money.
Other things are flabergasting, devastating, pop your corking, bust your wallet HIGH!
if I had brackets I'd use hardware store chain.. or i'd just make hte bracket.
I have proof oil chain on stays and checks.
as UD said. the chain is NOT the weakest link.. :)
Well I know New Holland is going to be higher just because of the name, but I'm assuming it is also better quality metal. Do you all agree that the metal will be thicker and stronger? I think I'm going to do what souNdguy said and go with hardware store chain. My problem is everything is worn out. I have brackets but they've been welded and I've got new tires on my tractor and I don't want the disc swaying into them and ruining them.
those kind of parts, I usually watch ebay for a part-out.
They usually go cheap and fit in a flat rate box.
(and are the real deal from ford)
If you just need the chain, plus one on making your own
from hardware store chain.
or if you hate to go to the store, like me,
cut a few pieces off your tow/work chains.
