I have two very cheap meters. I put a charger on a battery in the Saturn Vue. I tried to check the voltage at the battery to confirm that the charger was charging the battery. I was getting very low readings that varied quickly, going up and down. I tried both meters, and they both got the same irregular readings, with the battery in the vehicle. I removed the charger and still got inconsistent reading. I thought that the meters were faulty. When I checked a battery that is in the garage, I got a steady reading. So now I am thinking that must be a problem in the Vue. I know the ignition switch has a problem and a dealer is going to check it out on the 28th. So can someone explain to me why the readings on my cheap meters were jumping from 2.5 to 5 to 3 to 7 and 10 to 6 and eventually 12.4?
TY
SDE
TY
SDE
