Hey all:
I've got a 1020 3cyl gas 135cu.
Last winter we had the thing split, and hydraulic system and power steering rebuilt. It was delivered in the fall and we only ran it a bit. Fluid level was fine. We had problems with the mower that needed attention, so the 1020 sat until recently.
Our manual suggests to check hyd. fluid with engine warmed up. At first start-up a few weeks ago, we warmed it up at idle for 10 minutes or so till it reached 170 degrees. We operated the clutch and the 3 point hitch several times (but not the PTO).
Checked the dipstick and it was dry!!! We were so upset: after years of leaks and lots of money for the last fix. (We had placed cardboard under the tractor last fall, so could see that no fluid had dripped out).
So, we gradually added fluid as recommended in the manual: engine idling, checking dipstick unscrewed. We figure we added at least two gallons to get the fluid up to the top mark on dipstick. We could not imagine how we had lost two gallons.
Then, we ran the tractor with the mower for about one hour.
Before we shut it down, we checked the hyd fluid. The level was all the way at the top of the dipstick, way over the top mark!
What the.....!!!!!
So, I imagine the fluid was 2 gallons overfilled. But... Why wasn't the level showing when we warmed it up to operating temperature at idle? How the heck do we check the hydraulic fluid level?
Any insight would be appreciated.
Joe O
What the.....!!!!!
Joe O
