Chevy 5.3L question
kcm.MN
Location
NW Minnesota
On our 2004 Chevy, I took the throttle body off to clean. Went to put it back on and the harness connector lock (small white part) was missing. I found that, then realized that the part the lock hooks to was also gone. Not sure if I broke it or if damage was previously done.
Have found replacement pigtails to wire in, but have a question before I order. In the photo below, does the connector come apart? Meaning, the can the pink part (yellow arrow) separate from the black connector (green arrow)?
([i:208e8da5ec]not my truck - pic is from online[/i:208e8da5ec])
The pink part is the terminal lock. Yes
it comes off to remove terminals. Do you
have any shops around you could see if
they have a cutoff connector? I save
stuff like that from used engines. That
connector is a lot to spend for a clip.
You DO NOT want to splice that connector.
The electronic throttle is very sensitive
to voltage drop. Spliced connections
wreck havoc with the TAC controller.
Thanks guys. I figured that connector assembly could be separated, and figured that was good injuneering so one could buy just the replacement end and not a whole new harness assembly. Silly me! Still have to get an entire harness - or pay an awful lot for the one part you DO need (a pigtail assembly).
Wife suggested I just twine it up, so looks like I'll be getting out the zip ties. Wouldn't even mess with that but we have 20+ miles of rough gravel roads to drive on.
(quoted from post at 23:45:17 03/23/21) Thanks guys. I figured that connector assembly could be separated, and figured that was good injuneering so one could buy just the replacement end and not a whole new harness assembly. Silly me! Still have to get an entire harness - or pay an awful lot for the one part you DO need (a pigtail assembly).
I always get those type of parts from the local pick n pull auto salvage...they're a lifesaver for the OEM stuff. Very cheap too.
