It's not hard but you will have to buy some parts. The biggest deal is figuring out what you want to do with the electronics.How hard would it be to swap out my 350 and replace it with a 2004 5.4 in my 95 Chevy 2500 with 4L80 transmission?everything needed for the 5.3 is there on the engine less whatever it takes to swap it over
The bell housing are the same but you only use 5 bolts.you would have to know if the engine block bell housing pattern is going to mate up to the 4l80. i dont know that 5.4 engine. i had a 95 with that trans. and the 6.5 diesel.
The electronics and namely the fuel injection. Also the data the transmission needs to operate/shift. You would need to get a system like Holley has available that mix/mashes the electronics. Look like they start at about $1500.It's not hard but you will have to buy some parts. The biggest deal is figuring out what you want to do with the electronics.
It’s throttle body now and the 350 only has 40,000 miles on it.I just want more hp for pulling a trailer.a better throttle body and intake for the 350 is an option.I’ll call Holley tomorrow to pick their brainsMounts and bellhousing pattern should interchange. The wiring could prove to be a nightmare, unless you are good at that. Then there's fuel delivery if one is and the other one isn't FI. The in-tank fuel pump for FI puts out a lot of pressure, and will overwhelm a carburetor without a fuel pressure regulator. steve
Sorry, red and I must have been typing at the same time.
I imagine the other engine is available? But, if you are planning on adding power, I'd favor a newer big block, like a 454 for towing.It’s throttle body now and the 350 only has 40,000 miles on it.I just want more hp for pulling a trailer.a better throttle body and intake for the 350 is an option.I’ll call Holley tomorrow to pick their brains
I can get a used 5.3 for 500 bucks with 140,000 miles on it.idk if I should just stay with my 350 and boost hp on it if it’s about the same money anyway.I imagine the other engine is available? But, if you are planning on adding power, I'd favor a newer big block, like a 454 for towing.
As in same price to convert everything to make the 5.3 work or same price to improve the 350.290-300 hp would be enough for what I pullI can get a used 5.3 for 500 bucks with 140,000 miles on it.idk if I should just stay with my 350 and boost hp on it if it’s about the same money anyway.
I would tune the 350. The time and dollars to do the swap for improved pulling get a 6.0.As in same price to convert everything to make the 5.3 work or same price to improve the 350.290-300 hp would be enough for what I pull
Ya that 6.0 is a good engine in my experience.the 6.0 in the company truck has 375,000 miles and is still strongI would tune the 350. The time and dollars to do the swap for improved pulling get a 6.0.
Do your homework as newer 5.3 and 6.0 engines build their HP at much higher 5200 RPM that your TBI 350 4000 RPM engine is capable of running.How hard would it be to swap out my 350 and replace it with a 2004 5.4 in my 95 Chevy 2500 with 4L80 transmission?everything needed for the 5.3 is there on the engine less whatever it takes to swap it over
What is a 5.4LHow hard would it be to swap out my 350 and replace it with a 2004 5.4 in my 95 Chevy 2500 with 4L80 transmission?everything needed for the 5.3 is there on the engine less whatever it takes to swap it over
$500 for a used 5.3 engine is about the same as the exchange core charge for a rebuildable 5.3 engine. Rebuilding a 5.3 would cost another $3000 to $6,000. Unless I knew and really trusted the seller I would not rely on a $500 late model engine to last very long, especially if worked hard.I can get a used 5.3 for 500 bucks with 140,000 miles on it.idk if I should just stay with my 350 and boost hp on it if it’s about the same money anyway.
