TheOldHokie
- Location
- Myersville, MD
This is a new post in reference to the previous one on zinc levels in oil. I decided to start new to reduce the number of responses cluttering up the thread. I'll use Stewart's response as the new starting point.
There is indeed an abundance of confusion and misinformation. The Chicken Littles of the world latch on to a small piece of "real" information and the next thing you know the sky is falling. A big problem is that most of us are not engineers with any real understanding of the issues and that is compounded by the fact that we don't have the actual API specification to read leaving us reliant on somebody's description and interpretation (not that we would likely understand it even if we did have it). I did a little more research and learned a few new things not the least of which is that some of the things I had "learned" in the past were wrong. I started out looking for info on actual levels in current products and found this nice table detailing the levels in most if not all of the Mobil 1 product family. I realize it is only Mobil products but it had some very revealing information in it - too bad other manufactureres ae not so forthcoming:
[u:4787cde422][b:4787cde422]Mobil 1 Product Guide[/b:4787cde422][/u:4787cde422]
I immediately noticed an anomaly based on what I thought I "knew" from my previous reading onthe subject. A number of the oils that are licenesed SM products have zinc and posphorus levels higher then the new 600/800 PPM limit. For example Mobil 1 SAE 0W40 is a a SM licensed product and has zinc/phosporous levels of 1100/1000 PPM respectively. How can that be? The answer was found in this tech bulletin from Amsoil - the reduced SM limit only applies to specific viscosity grades:
[u:4787cde422][b:4787cde422]Amsoil TSB MO-2007-08-08. 1[/b:4787cde422][/u:4787cde422]
Further research turned up Amsoil TSB MO-2006-10-06 that provided even more background information. The empahsis was added by me.
Bottom line - unless you are building racing engines it's not likely an isue for you. And unless you do a lot of research you are not going to know what the zinc and phosphorus levels are in an off the shelf oil unless you have read and understand the new requirements and you get detailed product data from the manufacturer. If you are driving a Mercedes or BMW and using their SAE 0W40 recommendation the Z/Ph levels are likely way up there - probably not a coincidence. And don't forget - if you have a diesel the diesel motor oil standards are different from the gasoline motor oil standards. Probably a reason for that as well....
TOH
(quoted from post at 00:10:57 01/20/11) I've got an older BMW motorcycle with the air cooled boxer engine, and that is a real pain to find oil for. According to BMW, only API grade SF or SJ oil can be used. I can buy the BMW brand oil at about $8/quart (the filter is about $30), or I search around. When API started changing things around, they claimed that the SM rating met all prior oil ratings; but BMW maintained that you still had to use SF or SJ. It makes for a lot of confusion.
If I recall correctly, it was a zinc issue. The wet clutch required a higher sheer strength or something, and the tappets liked the particular additives found in SF and SJ rated oil.
I guess some older engines were just designed with very specific lubricants in mind.
[u:4787cde422][i:4787cde422][b:4787cde422]During the development of API SM/ILSAC GF-4 the antiwear requirements of flat tappets were given particular consideration by the engine manufacturers and by the oil industry.[/b:4787cde422][/i:4787cde422][/u:4787cde422] Engines with flat tappets were used to qualify API SM/ILSAC GF-4 oils. The anti-wear requirements of these tests are severe. In one case where the same Sequence IVA engine test was used for previous higher zinc and phosphorus oils, the average camshaft wear limits were reduced, allowing only 90u max wear for API SM/ILSAC GF-4 oils compared to the former 120u max wear limits. The results showed that API SM/ILSAC GF-4 oils protect factory designed flat tappet/camshaft engines just as well as previous higher phosphorus API SL/ILSAC GF-3 oils. If the engine is new, rebuilt or is modified from stock with high-pressure valve springs, proper precautions should be taken to insure long camshaft life. These recommendations apply regardless of the lower zinc and phosphorus associated with API SM/ILSAC GF-4 specifications.
High-performance modified engines benefit from oils with superior film strength and anti-wear properties. The flat tappet/camshaft lobe interface is the one area in an engine that has extreme contact load. That load increases significantly where non-stock, high-pressure valve springs are used. The use of properly formulated engine oils for this application will help reduce wear and extend the flat tappet/camshaft life. [i:4787cde422][b:4787cde422][u:4787cde422]There are many more ways to achieve good anti-wear performance than just using zinc and phosphorus compounds alone. Zinc and phosphorus are widely used because they are the most cost effective solutions to achieve anti-wear properties[/u:4787cde422][/b:4787cde422][/i:4787cde422].
TOH
