chips in gear teeth
INCase
One my Case 800 there are several chips out of a few teeth on one gear. a couple teeth have a bit of an angle on them while others next to them are straight. the mating gear looks fine no problem. All other gears except the reverse gear (I can not see the reverse gear yet as its under oil). Look fine. Not sure if that gear (2nd) runs with reverse or not. Didn't notice anything when driving.
What would cause this if all other gears look ok?? bad iron??
Thanks.
not on a case,but on a 1086ih this was caused by the park lock pawl.like putting the tractor in park while rolling or shift linkage misadjusted and putting in gear while park pawl is still engaged
The teeth that have a bevel on them either slide into another gear or another gear slide into them.
Those gears in constant mesh with another gear most likely have a bronze synchronizer next to it and it has smaller beveled teeth on them. If the synchronizer teeth get rounded at the end their usually wore out. The teeth should have a good noticeable sharp angle or point on them.
thanks, these gears are NOT beveled gears from the factory. What I am seeing is a slight angle warn in between one gear tooth to the next in the same gear. One tooth is straight the next has an angle.
