christmas tree
I do not see any reason the return line to the reservoir could not be plumbed int the input port of a second valve. Be sure the hoses will connect, and be sure the fittings are hydraulic rated. Also make sure of stable mounting brackets. Do not try to use them both at once, dangerous motion acn occur when one feeds into the other. Jim
If you need double hydralics,install a double spool valve.I did,thats the only way!It is mounted to the right of the seat,down on the deck.the handles were lengthened for ease of operation.Its as handy as on my newer tractors.
