Chrysler 225-powered tractors?
cam.man67
I've been wondering about this for a while. My daily driver (and occasional farm vehicle when my trucks are occupied) is a '68 Dodge Dart. It's a slant 6 car, runs like a top. I have had practically no issues in the past 5 years, and usually put about 8000 miles a year on it. Here's a pic, if interested:
The reason I bring this up is I know Chrysler built industrial versions of the 225. It didn't differ all that much from the engine in my car, but that motor found its way into forklifts, swathers (Hesston, I think?), and various generators. I feel like it would make a great tractor engine, but I've not found any company who ever built one. I've heard of a few tractor repowers using Slant Sixes, but I've not seen one in person or even any pictures. Does anybody have any experience or information about using this motor in a tractor application?
AFIK no OEM tractor manufacturer ever used the slant six.
We however had late 60's Case combine with a factory-installed slant six - a Case 800 if I recall. It was probably the most reliable and trouble-free engine we had on the farm back then.
My first two vehicles ('62 Dodge Dart and a '66 Plymouth Fury) had slant sixes. Both ran over 200,000 miles - the engines were still going strong when the bodies simply rusted away.
So I agree - the slant six would have probably been a good engine for a tractor in the 60 - 70 HP range.
960 case combines from the late 60's also used the "leaning tower of power" along with a lot of john deere and hesston swathers. My first car, a 76 duster had the 225, while my sisters duster had a smaller
cube like a 179 or something like that. They were a good engine, cracked exhaust manifolds, seemed to be there weakness.
You are right on them being indestructible. Have an old Yale forklift with the slant six in it. Old enough to have a clutch and 4 speed tranny (2 foreword, 2 reverse). Has been ridden hard and put away wet for years and still runs like a top.
One of the toughest engines I have ever encountered. Dad had a number of late 70's Plymouths including the '69 Valiant he maintained was the best car he ever had.
Massey (Mac Don) swathers and Massey 300 combines used the slant 6.
While not a tractor , I do have these two slathers
with 225 slant six power plants. MF 655 and JD
2320. Both run just as they should, with only simple
mantaince . I have own two Dodge vehicles with
225 "s , a 66 Valiant , and a 85 pick up. The were
good little cars. Bruce
I know it's not a tractor but still an interesting machine with a
Chrysler 225 slant six industrial engine. Here's my RO Products
Mobile Hammer.
I put quite a few hours on one of those years ago. Broderson with a diesel and a cab, but the same machine. The company got rid of it when it became too high maintenance compared to a hydro hammer.
Our Super 92 Massey had the 265. It was a very good engine. It was a little thirsty in a good crop but barked right along all day. I can remember bringing 5 old metal Skelly oil cans of gas out to the field at dusk to get it enough gas to last through to stopping time. It had that side draft carb on it and it seemed like it flooded easy.
Something with a frame would be your best bet. Farmall F12,Massey Harris,Oliver,something of that nature. Not saying it wouldn't take some machining,but it could be done.
The 225 slant six was introduced in 1960... All Simpsons,Wards,Jumbos,Customs,Lehr Big Boys,Fridays,OMC's,Norseman-etc of that time period used Chrysler flat head 6 engines...
A little O.T. What were the differences between a car/pickup 225 and an industrial? I would imagine they used a belt drive governor, maybe a different carburetor, a different cam? I would suppose a lower rpm might need those. Also If in a continuous duty application (tractor/combine etc) they would probably be downrated for horsepower compared to the automotive application. Anyone know what horsepower rating they used in industrial?
The spec for the Chrysler model HB 225 in my mobile hammer is 98 HP at a governed speed of 2600 RPM. According to the Maintenance and Parts manual for the Slant 6 Industrial Engines there were two types of governors, mechanical and velocity. The mechanical governor is "belt driven from the governor drive pulley on the crankshaft." My mobile hammer has the velocity governor which is a device inserted between the bottom of the carb and the intake manifold and governs based upon the velocity of the air/fuel mixture passing through.
I have a Hesston 6450 windrower with a chrysler slant 6. That little guy just purrs like a kitten with a saucer of milk. running a 15 foot draper head,
Not positive but I believe industrial engines were cammed differently from car/PU engines so torque peaked at a lower RPM. They likely had different carburetor jetting (or more likely completely different carbs) as well. Depending on the application they also had different (larger) oil pans, larger radiators, different alternators, etc..
Adjustable speed governors were Pierce or Hoof mechanical. They were belt-driven from the fan/water pump pulley. Limiting speed governors were King Seeley(?) velocity type - essentially a 2nd, speed sensitive throttle plate - bolted between the carb and the manifold.
Depending on the application industrial 225's were rated the 70 - 80 HP at 2,000 RPM. By comparison automotive 225's were rated for 145 HP at 4,000 RPM thru the early 70's. This had dropped to 100 - 110 HP by 1972 as smog controls were added.
The ones for real work had forged crankshafts, the ones for lower powered cars had cast cranks.
They were good engines, would run well over 200,000 miles in a car with reasonable care, and this
was before a lot of engines would do it. Later ones had hydraulic lifters, not so good.
(quoted from post at 04:21:24 09/17/16) I know it's not a tractor but still an interesting machine with a
Mobile Hammer.
Tell me more about your RO? Looks like a 4x4 one ton chassis.
I don't think it's a truck chassis because the whole chassis can
hydraulically tilt 10 degrees in either direction to level the hammer
on a side slope. The axles are Spicer 70s which were used on trucks,
but with a 6.17 ratio. The machine has a hydraulic creep feature -
can drive the machine with a hydraulic motor from the rear hammer
operator station. The hammer weight is 1075 lb. Not including tools.
