CIH 2344 combine code
crsutton81
For what it's worth, this is Farmboy 81. With all of the rain we've had, my old phone drown. Got it replaced and this new one will not let me log in under my old handle so I had to re-register. Anyway, on the 2344 I get a Hdr 50 code displayed in the A post info screen along with a orange flashing light of a header picture. The head height numbers never change. Always reads 58 which is unusual. The corn head is slow to pick up also. Everything is connected as it should be. Has the potentiometer on the feederhouse bit the dust ? I have gone through the setup about the max up and down header height. Suggestions???
I think Striker782 may have your answer in the attached AgTalk post. That is probably a far better place to post that question if you still can not figure it out. YT support should be able to get you posting under your original handle.
Try here
Thanks Used Red. I had forgotten about doing the recalibration thing. Been awhile since I've had to do anything to it and sure didn't want to put a new pot on if that is not the problem. Last one I put on a friend's machine was around $400. Kinda pricey if it doesn't fix it.
