CIH 9170 4WD
Anonymous-0
I have a 9170 that is losing the hydraulic oil from the reservoir and pumping it into the transmission. Has anyone experienced this problem? Is it hard to repair? I assume it's just a seal between the two that has failed. The tractor has around 3500 hours. It will lose 10 gallon in 2 hours or less.
I think the Hyd. pump drives off of the transmission on those tractors. If so it is probably a pump seal that is leaking into the transmission.
Brother in law wrenchs on tractors for a living. He says the pump seal is toast and that it is a pain in the a$$ to fix. Good luck
