old codger
I am not sure I am turning the tractor off properly.
I have recently aquired a 35x and the battery seems to loose charge over a couple of days while sitting there. I have charged it back up with a charger and then had the positive lead disconnected for 3 days and it has held charge.
So when you operate the key to activate the starter motor the key then springs back to the off "0" position and this is the position it sits while the tractor is running. In the manual it says to stop the tractor you pull the injector pump stop to stop the motor then turn the tractor off. But the switch already is off.
So is the tractor totally off once I have pulled the pump pull and if so
do I have a fault in the wiring ?
