Fergienewbee
A couple of years ago I bought an implement the auctioneer said was for breaking up clay clods. I can't post a picture, but here's what it looks like. It has two shafts inside a squarish frame. The front shaft has what can best be described as eight or ten, four-blade propellers, each blade set at an angle around a thick disc. Each propeller is separated by spacers about six inches apart. The back shaft has several more smaller propellers shaped the same and spaced closer together. It is designed to be pulled. Is there a name for this thing?
Larry in Michigan
Larry in Michigan
