Cleaning combine -MF300
Errin OH
One of the things that didn't get done was a proper cleaning of the thresher. On the 6600 I had it wasn't terrible because I could access it through the front and blow it out the back.
Not really seeing away to do that on this MF. Thoughts / something that worked for you?
On another subject, while inspecting I see the is a heavy canvas between sections under the combine. PO has stuffed splits / tears with rags. My plan is to properly repair, as in replace them. It sits just behind the concave under the combine. Not sure what it is called. Having trouble looking it up since I do not know what it is part of. Ideas?
look up agco parts book under guest user and you can look at a parts breakdown, been a long time since I worked on an mf but the canvas I think you are referring to is attached to the front of the grain shaker pan,can be replaced with a thin flat belt or baler belt
