cleaning out a block and raidator flush
pinball
what do you all use to flush out the block and radiator on a 961 ford. think I might have some blockage some where. thanks
Castle Power Flush. Works very well. Follow instructions closely or run the risk of damaging soft parts such as liner O-rings. A guy I know left the flush in over night and wound up pulling the motor down to change liner O-rings.
I use vinegar straight. Fill it up run it till good and warm and then let cool and rig up a way to hook a garden hose to the block drain and back flush it till the water comes out looking clear. A real bad bock up system some times take 2 or 3 flushes but it has always worked well for me
961s run uphill all the time. Remove the temp gauge bulb after you circulate the cleaning solution for awhile so that solids can run out the back of the head. Otherwise you will have a plugged area back there.
One word of caution on the vinegar. I too have used it with good results. However, vinegar is a mild acid. To make sure the acid is totally neutralized, after flushing the system out good, flush again with one of those dishwasher soap pods.
I rarely use flush, but if I did, I would temporarily remove the thermostat to get some full flow, vigorous circulation.
Run it at full speed for several minutes, drain it, and repeat.
Like Showcrop said, remove the temp sender to get the dirty water out, and open the radiator drain cock. Continue to run the engine with the water hose in the radiator while it's flushing until the flow is clear and all the flush is out of the system.
While you?re at it as a continuous help, place a magnet in The radiator to pick up solids that flow through the radiator. Let?s face it ,a block is cast-iron, at least the older Tractors. CM
Permatex 80030 will clean it but don?t use it in anything aluminum because it will eat it
Untitled URL Link
