Cleaning radiator
I?ve flushed them with laundry detergent sometimes it takes 4 .or 5 times but it?s cheap and easier than pulling the radiator I just fill it in the morning and drain it at the end of the day
white vinegar - water 50/50
fill up run till it gets hot leave sit over night
then drain and see what it looks like
may have to repeat
I have filled a rad with CLR and let it sit. Lots of effervescence as the lime disintegrates , then when it appears clean I take the garden hose and flush it.
I have taken the plastic tanks off and used a stiff rod to remove the crud then daubed on silicon and put it back together. Still working good.
I got this brain storm this summer to try something new. I drained the anti freeze out and filled my radiators with distilled water. I figure that it will absorb the calcium. Next fall I will drain out the water andfilter the anti freeze thru a paper towel and put it back in. We'll see if it works.
