(quoted from post at 01:09:32 10/19/19) you can try vinegar as it is cheap , with main cost being your time. I flushed and did vinegar soak & run on 3 separate occasions on same tractor/radiator and wasted several hours of my time. IR photo shows still clogged. New radiator fixed it.
red is hot, including part of alternator peeking out the side.
By the time you pay shop to remove tanks,rod out core, and re-solder tanks, you will have bought a new radiator, but still have an old rotten one.
(quoted from post at 14:09:32 10/18/19) you can try vinegar as it is cheap , with main cost being your time. I flushed and did vinegar soak & run on 3 separate occasions on same tractor/radiator and wasted several hours of my time. IR photo shows still clogged. New radiator fixed it.
