stevieb49829
- Location
- Spirit Lake, Idaho
Being frugal (wife's translation is CHEAP), and putting my last new lens in my autodark helmet, I decided to try some stuff. I have, in the past just washed them with soapy water to get SOME of the smoke off the lens, but it didn't work well. Through a little trial and error (lacquer thinner/campstove gas did NOT work) I settled on a two step process: PB Blaster penetrating oil on a paper towel worked in to get the smoke and splatter tracks off, finished with another paper towel using plastic headlight lens cleaner. The lens cleaner I used is an old tube of Scotchbrite vinyl and plastic cleaner. I'd been using just the cleaner, but it didn't cut through the smoke like the PB Blaster does. Try it and you will probably get more miles out of your smoked up lenses.
