Cletrac HG42
dnd
Just picked up an HG42 today, Couple of Question
1: I saw the serial number plate on the right side of the engine, where would I look for the serial number plate for the unit?
2: it does not have a front grille, any ideas if these are available after market. And where.
3: There is not air cleaner, Can someone send me a picture to get started in want I need.
4: it has a foot rest on the right side, but just a piece of flat iron on the left. Any idea where I could find the correct one.
5: engine turns over, no gas in tank and a magneto so Ill get a battery in it next week turn it over and see if I got fire.
6: the radiator sides are loose, looks like the solder can apart. Assume I can just clean up and melt whats there back together?
More later. Dan
Hello. I enjoy a newer OC 46, 4 cyl Hercules engine. My air cleaner is oil bath- through hood aft of bat box , uses a plastic bowl between top and bottom metal covers. You should contact the Zimmerman's- East Pa. They know these machines, restore, and sell new and used parts. Nappa can get me parts for the Wico Mag. Best of luck- enjoy.
A couple more places...There is also a forum on Facebook for these little crawlers but I don't have a link for that...https://www.olivercrawlers.com/miscellaneous-2a
https://antique-tractor-parts.external_link/tractor/Oliver-Oc3/96
