Closed center wagon wheel
I recently bought what I think is a coop wagon gear, it is made by electric wheel, and it has 16? closed center 5 bolt wheels. I need one for sure probably two. Does anyone have any or know where I might find a couple. Thanks Michael 816 898 7277
Heywheel would have them or make them for you. Or you can make them yourself. Just cut the center out of your shot wheel, and weld into another good wheel of the same diameter. If you look closely sometimes you can see the spot welds or rivets. I then cuth them loose and weld into other wheel. By doing it that way it stays centered so it turns true, then with it on a hub you can check for sideways true then weld it up.
5 bolt wagon wheels are kind of a one size fits all thing. Any 5 bolt wheel from any other wagon should fit. Even older, Ford 1/2 ton pickups have the same bolt circle pattern.
