shaun wallace
- Location
- Stith, Jones County Texas
What all has to come off or out to change clutch cable ? End broke off at pedal. Looks like not much room at valve end
I will be watching the replies as I need to replace the cable on a 2390!What all has to come off or out to change clutch cable ? End broke off at pedal. Looks like not much room at valve end
I'm not familiar but can you pull new cable through with old cable?What all has to come off or out to change clutch cable ? End broke off at pedal. Looks like not much room at valve end
What do you do at the valve end?I remove the dash then the console to get to the nuts on the end of the cable under the pedal. May be I am missing an easier way.
Struggle. I have several different brands of open end wrenches and from one wrench to another the angle of the open end sometimes is just enough different that by using one and then another that eventually I get the cable tight. Also I pop the plastic plug out and move the PTO cable out of the way.What do you do at the valve end?
Did you get the job done?What all has to come off or out to change clutch cable ? End broke off at pedal. Looks like not much room at valve end
