My 9N sat garaged for a couple years before I reassembled the rear end after repairing various issues. Before I tore it down the clutch properally disengaged in order to shift into gear.
Ever since I reassembled the tractor I am unable to shift into gear from nuetral because the transmission is spinning (clutch is not completely disengaging). Instead, I shift into gear by starting the tractor in third gear (with the brakes on) rather than nuetral. This keeps the transmission from spinning and allows me to shift from third to the gear of my choosing.
I have played with the threaded adjustment that controls the pedal height to no avail.
1. I dont plan to split the tractor before winter but what is the likely correct fix for my problem?
2. Is there a bandaid I can apply without splitting the tractor? I've read posts about spraying carbuerator cleaner through the starter opening. Also applying talcom powder to the clutch plates(Where do I apply, or does this require a split?). Will either of these items help my symption?
3. Someone recently suggested it is a good idea to block the clutch pedal down if the tractor is going to sit unused for more than a couple days. This sounds extreme. Does it do that much good?
Thank you,
TB
Thank you,
TB
