Clutch Material
Dremel
Dang mice. This clutch is toast. Any thoughts on clutch material on a tractor with a loader? Organic or ceramic?
Does this look like the original clutch?
Thanks,
Bill
I would go with stock type myself, those clutches really last and all of mine always work so smooth, unless you are a clutch rider should last you a long long time,, my VA does not have a loader but it still has the same clutch in it it had when I bought the tractor in 1978 and I use it a lot, just my thoughts though
cnt
Thanks guys, parts on order from YT
Clutch, pressure plate, throwout bearing, pilot bearing and rear main seal. If you're gonna do it...
Thanks Nutty! I went with the cheaper organic material. The last one last prolly 40 years at least so it won't be my problem :)
