clutch on 8n
sixone50
I have a 49 8n and the clutch seems to stick. The clutch does not seem to disengage the transmission when the clutch is pressed. This is not just when first starting it is when first starting and when riding for a few minutes and press the clutch it just keeps going and I have to get on the breaks real hard and then it will disengage or if it is where I can let it go for awhile it will disengage by its self. I block the clutch down when I am through with the tractor for the day. Any ideas on what is wrong would be greatly appreciated.
(quoted from post at 16:08:22 04/08/16) Reaching WAY out here but is the PTO engaged?
Hooked to anything?
PTO is disengaged and not hooked to anything. Not changing just trying to stop and push the clutch in but it keeps going for a few seconds then disengages.
Not changing gears just trying to stop and put the clutch in and it keeps going for a few seconds or until I press the brakes.
Block your clutch down then inspect the linkage closely.
Occasionally the linkage that connects to the round shaft
going into the transmission cracks and does not fully turn
the round shaft to disengage the clutch.
The crack may not be visible until you depress the clutch
pedal and the crack opens up.
