Clutch pedal return spring on 445
WrenchTurner
I need a 10A2218 clutch pedal return spring. Mine is missing so I don't have anything to go by for matching. If anyone has a 445 (utility, not universal) with a good spring on it, I could sure use photos and measurements. Thanks!
If all else fails, try various springs you have laying around and see if you can find one that will work. Probably won't need an exact replacement
I believe you can order that from Welters 417-498-6496, or (maybe) any AGCO dealer who used to be a MM dealer
If all else fails, I'll find something somewhere, but "all else" hasn't failed, yet. I'm just getting started. Thanks for the input.
Available from Agco
Yeah, I saw it was available thru Agco and contacted 2 dealers. Never heard back. I guess I'll have to call them. I wish they wouldn't advertise an email address on their contact lists if they're not going to answer them, which is increasingly the case. But I also try not to order small stuff like this when I don't have to because of the exorbitant shipping most dealers charge. Of course, if someone would respond with the pic/specs I asked for in the original message, I might be able to match it. But what are the chances? Probably not a lot of 445 Utility's in this forum. Thanks for the input hymie2lt.
If you call Welters, either Lois or Eileen will answer, they are the parts dept, they probably know more than most people calling about the parts and required "extras" if any 417-498-6496
