clutch pressure plate
Status
Not open for further replies.
Craig-HT
I ordered a new clutch nnalert. for my yanmar186d and it is set up 3 roll pins on the flywheel. The clutch I took off had only 2 pins. Is it ok to use the pressure plate you sent me even though it will only be on one pin? Also what are the torque specs for the pressure plate? Thanks.....Craig
<QUOTE author="Craig"><s>
</s>I ordered a new clutch nnalert. for my yanmar186d and it is set up 3 roll pins on the flywheel. The clutch I took off had only 2 pins. Is it ok to use the pressure plate you sent me even though it will only be on one pin? Also what are the torque specs for the pressure plate? Thanks.....Craig<e>
/e></QUOTE>
I recommend you contact Aaron directly. Sometimes he does not come on the forum for several days. It would seem to me that 1 alignment pin is no better than no alignment pin, if even needed.
Yes, some of the first older style used several roll pins to help you hold up the pressure plate while you started the bolts... not sure why since the plate only weights about 7lbs. Anyway... the new style pressure plate is missing those holes. Just pull out the pins that don't line up.
Status
