I put in a reman motor in the tractor and was going to replace the clutch, pressure plate and throw-out bearing. The pressure plate and throw-out I received were the wrong configuration, but the clutch plate was the same, so I reinstalled the old pressure plate and bearing with the new clutch pad (plenty left on the clutch but since I had it split open I thought it would be a good idea to change them out). We have replaced 3 engines in other tractors and 6 or 8 clutches so this was not new to us. It all went back together fine and the tractor started and ran without a problem. The problem(s) came when we pressed down on the clutch. It wasn't there. Nothing happened. The lever on the side of the transmission that operates the clutch moved freely back and forth by hand without resistance. Simply no clutch at all. I know we installed something wrong, but I wanted to have an idea of the problem before we split the tractor again. If that wasn't enough, the power steering is not working. We installed a new filter but did nothing else to the system except reconnect the lines running to the cylinders. The steering wheel doesn't want to turn. Any help someone could offer would be appreciated.
