clutch/shift problem
JT90
I have a 1976 ford 3600. I had a new clutch installed because of age, hours and pto clutch bad. The tractor shifted good before install of new clutch but now with clutch pedal depressed the gear shifters seem to hang up. It's like you can't pull it out of gear. If you kill the engine they come out.
I took the transmission filler cap off and with light watched as I depressed clutch with engine running and the gear from clutch stopped. Just was hoping that someone may have had same problem after installing new clutch.
Thanks for any help.
I changed transmission fluild to.
Is the petal free play adjusted correctly and does the PTO Clutch release properly? If all of that is Ok,Id say the clutch disc is tight on the transmission splines or whoever installed it forced the halfs together and warped the clutch disc.
Have inch or more free play and the pto works proper. The guy that installed it said that the clutch came as a unit and only needed to be bolted on.
