Clutch wont fully disengage
jd1520
I was doing some work on Saturday and then the clutch doesnt want to fully disengage so I have to go to idle and bang it in there to shift ...not good long term solution
I adjusted linkage so I have maximum throw but it still not disengageing fully??
did I break something or is it just wore out?
I figured it would slip in gear if it wore out not this not disengaging stuff
Is there something I can check or try before I tear it apart?
Strong chance a dampener spring is loose in the pressure plate and holding things up...I'm talking about one of the springs in the center of the clutch disc...
You could have a broken operating bolt on on of the clutch fingers. Pop the cover off the clutch hosing and look at them. No matter what you are going to split the tractor.
I had a simuliar problem on a 2520. The clutch looked like a wavy potato chip all the way around. Just wore out. Paul
