CO2 flow gauge regulator
Harbor Freight has a CO2 flow gauge regulator, my question is. Can I replace the flow gauge on the regulator with a pressure gauge to use with CO2 on a kegorator? Or is a flow gauge reg. different from a pressure reg. other than just the gauge? This regulator has a flow gauge not the floating ball flow meter like on my mig welder. thanks
Yes, in fact mine came with two pressure gauges. High pressure for tank side and lower pressure for after regulator. Unfortunately I knocked my tank over and busted the low pressure gauge. Doesn't leak, but doesn't work either. So when ever I have a pull off the tap I just crack the valve and wait until I hear it stop pressurizing and shut it off. I got into this habit when I had a seal go out on the tap and lost a whole bottle over night. Also if you haven't bought your tank yet, spend the extra money and get a 20# tank. The local grow shops around here will swap out a 20# for ten dollars, whereas it costs thirty dollars to refill my little 5# tank. I've been meaning to get a 20#er but have more pressing needs for tractor parts. That and since everybody has raise the cost of a keg, it just isn't that much of a savings anymore. I do like the convenience though.
JD
Are you looking to control the pressure or the flow?
You may want to research this more, depending on your requirements. My understanding of flowmeters is: A flow meter/flow gauge is regulated to a fixed pressure when built and the regulator adjustment only controls the gas flow as the fixed pressure is built in. If a flow meter is working right you can not adjust the pressure, only the flow as witnessed on the flow gauge (which is where a low pressure gauge would be on a variable pressure regulator such as is used on an oxygen tank with a torch). You can put a pressure gauge on the hose and "dead head" it to find out what a flowmeter is regulated at. It will only go up to its designed pressure. Depending on the welding process people used different regulated pressure flowmeters/flow gauges.
The cheap style of flow regulator like that is just a pressure gauge that is calibrated in flow to an orfice in the line.
I have not priced them but I would check with Harbor Freight if you have one near by. You might be better off with a regulator than a new gauge.
