Tony in SD
I personally would not waste my time or money on undercoating. i just power wash the underside of my 7 foot mower after each mowing. Mower is 20 plus years old. Still works like new.
I’ve had a 38” Cub Cadet with one washout port and a 54” deck with two ports. They do not do a complete job. There are certain places that don’t get enough force to get it all off. Yes, it is the spinning of the blades that propels the water around. That’s how it’s supposed to work. Keep the deck lowered to the ground for it to work right. I always do it as soon as I’m done mowing.Those fittings aren’t worth the pennies they cost. Its completely worthless. All it does is run water over the blades, thats it. You’re better off just driving through a puddle with the mower on.
I went down the rabbit hole of media blasting and coating my deck with por 15 many years ago. Total waste of time and money. YMMV.
I won't say total waste of time for me, but also not worth the effort. The stuff flakes off in large chunks similar to what you'd expect with powder coating.
i have coated a couple of mine with that red coating for inside gear boxes, forgot the name now. but it hardly made any difference . the grass still stuck and have to wash them out. i think stainless steel would be of more help than any coating. there is nothing proven i have found yet.Anyone come up with a proven coating for the underside of a cutting deck.
I used spray on Graphite too, after I removed the deck, flipped it over and spent a lot of time cleaning. Applied 2 coats. Results: Not worth the effort.I used spray on graphite last time I worked on mine, not sure if gave any benefit or how long it has lasted. My JD 420 60" deck still cuts very well though.
What works is a 46" conventional mower with a stamped deck (nice and smooth internal contours) which only has 2 blades, not the clogging 3rd blade and welded deck on a lot of those with sharp corners that just love to collect and hold clippings... I have 2 of them and in the spring, like right now, they are all I use. Then immediately when finished, I use use a power sprayer shooting water under the deck (very carefully) with the blades running at a good speed to get the lifting action of the blade tips to assist in washing out the deck. Piece of cake and takes just a few minutes.I used spray on Graphite too, after I removed the deck, flipped it over and spent a lot of time cleaning. Applied 2 coats. Results: Not worth the effort.
I did the same thing, now every time I get done mowing I flip it up and scrap it out with a wide puddy knife.I went down the rabbit hole of media blasting and coating my deck with por 15 many years ago. Total waste of time and money. YMMV.
POR 15 converts rust. it is not a paint at all. when put on a sand blasted finish or sanded or just fresh clean mill finish steel, it has nothing to convert and is worthless. Try it on a rusted surface (with no flaking rust) and it works. JimI'll go one step further and say total waste of time. Many years ago the city I worked for had 3 of these leaf collection trailers. We spent a lot of time and money sand blasting and coating the inside of one with POR 15. Didn't last one season (5 weeks) and this use is nowhere near as abrasive as the the under side of a mower deck.
Do you mean human?Fluid Film
MY ANSWER: POR-15Anyone come up with a proven coating for the underside of a cutting deck.
For what purpose?Anyone come up with a proven coating for the underside of a cutting deck.
